Hi guys,
I experience an issue which may be related to this thread.
I own a 2011 Ford Fiesta MK7.
All of a sudden I discovered that when I try to deflect the AC air from the front to the windshield/Legs, nothing happens.
I took a look down behind the steering wheel and identified the blend door actuator.
I noticed that it's unable to deflect the air from the front to the legs (down movement) but successfully able to deflect it from the legs to the front (up movement).
Do you think, in high centenary, that replacing the blend door actuator will fix the issue?
How can I find the exact actuator model that I need? I want to make sure I buy the right one.
In addition, when I hit the button that controls the air circulation direction (to suck air from the cabin or from outside) nothing happens.
Is this related to the same faulty actuator or is this a completely different issue related to anothe part of the HVAC system?
Thanks a lot!
Itzik
