I also removed the sound blanket. Taped up every crack I could find that might let cool air bypass radiator. Running coolant temps of 235F with the stock 1.3 bar cap is actually about 35 degrees below boiling point of my 30/70 antifreeze/water blend, so its not like there is some coolant loss likely. Oil hits 260F, but again, good oil can take it for tracking.
What I would really like to do is remove the hokey flap stack adjacent to right side of fan shroud and replace it with a vertical oil cooler on back side of radiator, but the clearance is really tight. If I could get this arrangement to work, in theory it offers the most fluid cooling for least weight while still being daily friendly.
In meantime, heater works enough, just need to plumb the outlet that burns my right foot out the window with some flex hose.
