Thread Starter
#181
Totally you understand that on the MRX thread - it's not real friendly over there and has turned more into a beer guzzling contest at this point. I respect you man, you're doing your thing and doing it well. I've noticed the same shenanigans ever since I joined this forum and been on the tail end of some of that same type of talk. It's just insecurity. Glad you are happy in any case.
FWIW, to your current vs. delta observation, I did vDynos of all my tunes (Puma X47 installed 3 weeks ago) and saw about a 40hp difference between first and last tune revision. I did some pulls on slight decline on interstate on-ramp and that made the difference 60hp from the beginning. When the weather cools I'm getting a real dyno done to see where we are truly at.
How is traction in 2nd gear at WOT? Does the fact that the turbo spools a bit later eliminate traction issues? Or are you using traction control?
I have not driven much without ESC on the MRX setup, except for datalogging. I always turn it off at the track and basically leave it on when driving on the street. Traction control is always on. I have no real use for sport mode (although Ford suggests using it go get unstuck from snow/mud).
I have not tried to launch this car with this tune via quarter-mile style. I just don't drive like that, especially in low speed settings where I'd use second gear on the street. I have no real instance on the street where going hard to second gear is really getting me anything. Having said that, I have a Quaife LSD for what that's worth.
As for any "shenanigans," I've seen occasional rudeness or peculiarly aggressive behavior here (not that unusual for car forums, unfortunately) from time to time. Arguments usually have to do with conflicting technical performance POVs.
