Thread Starter
#61
[MENTION=283]meFiSTo[/MENTION] for the Mishimoto oil catch what connector did you use for the PCV connection? Looks nice and clean (almost stock). Tear apart the existing PCV hose? Nice build BTW.
"...Then you cut the hose off the quick release ends. Using an exacto blade, run two cuts along the length of the hose remaining on the nipples of the quick release fittings. Then pull the hose off. Push the hose supplied by Mishimoto onto the fitting. Then push the Ideal vacuum hose, then apply hose clamps and tighten. I like the clear hose, as it lets me know the OCC is working properly. FYI, you may need to rotate the quick release ends slightly from where they originally attached to get them to click on properly, especially the one that connects to the intake. Otherwise that one will pop off."
In my case, I had enough Ideal 5/8-in wire-reinforced hose (purchased 4-feet) to completely replace all the swapped out PCV plumbing, so the part in the note about the Mishimoto hose related to the Ideal hose.
