Logs with new DHM Intercooler
HIGH BOOST!! custom dhm tune. 3rd gear pull only got 4deg above intake air temp
http://datazap.me/u/drag4life723/high-boost-dhm-intercooler?log=0&data=2-3-5-6
Cobb OTS stg3 tune
40mph - 112mph only 25deg above ambient and 16deg above intake air temp
http://datazap.me/u/drag4life723/cobb-stg3-ots-tune-dhm-intercooler?log=0&data=3-4-5-9-12-15
Cobb OTS Stg3 Tune
115mph - 127mph 6th gear high load pull 30deg above ambient and 23deg above intake air temp
http://datazap.me/u/drag4life723/cobb-stg3-ots-tune-dhm-intercooler-2?log=0&data=1-3-4-5-8-12-15
Cobb OTS Stg3 tune
75mph to 100mph decel to 75mph back to 90mph 13deg above ambient and 8 above intake air (at largest gap you can see were charge temps drop below intake air temps)
http://datazap.me/u/drag4life723/cobb-stg3-ots-tune-dhm-intercooler-3?log=0&data=1-3-4-5-8-12-15
Here is some good info with the new intercooler. You can see were the charge air temps are blow what is going into the turbo plenty of time. At the very most i have only seen 30deg about ambient and 23deg above intake. When you see the logs on the stock intercooler you will really get an ideal of how much this is helping cooling.
Also take a note of how fast the turbo is responding to throttle and how fast it builds boost. No lose in spool or response!
Russ
