Since I see the oil issue in quite a few threads, I figured I would start a thread that contains the oil data for different oils that are super important to the turbo GDI engine world. A high NOACK volatility (ASTM D-5800) and SAPS (sulfated ash) contributes to carbon buildup on valves. There is different data floating around the internet that NOACK isn't as important as SAPS and everything in between so my best advice is to find BOTH low NOACK and SAPS.
Finding the NOACK, SAPS data, or both is proving to be a challenge for most OTS oils, including Motorcraft's own oils. Here's what I have so far. If you have data that I don't have, please post it. I will do my best to update the first post as it gets posted.
Please remember that the NOACK for a 5w-20 will be different than it's 5w-30, 0w-20, 10w-30 etc. counterparts. I have also found independent tests that show a particular oil has a different NOACK than the manufacturer shows (for example, Pennzoil Ultra has a lower NOACK in AMSOIL's tests than Pennzoil shows in their data sheet).
This data is for reference only. Please remember there is a lot more to oil than NOACK and SAPS, like wear properties, sheer resistance, and additives. This will just guide you to choosing the right oil for our turbo GDI engines.
One other test we should be particularly cautious with is the TEOST test (ASTM D6335). This test shows how the oil creates it's own deposits when exposed to heat. This is particularly important for GDI engines because the more deposits it creates under high heat, the more deposits will form on the intake valves and intake ports. It's also important even for water cooled turbos but especially for oil only turbos because a lower number will produce less coking in the center housing.
GF-5 spec upper limit for the TEOST test is 30 mg of total deposits formed.
Reference - NOACK below 15% passes the ASTM D-5800 test, but the lower number the better. Sulfated Ash of 0.5% to 0.7% = low SAPS, 0.8% to 0.9% = mid-SAPS, >1% = high SAPS
All oils meet Ford WSS-M2C945-A unless otherwise noted.
Mobil 1 Advanced Full Synthetic 5w-20:
NOACK - UNKNOWN
SAPS - 0.83%
Mobil 1 Extended Performance Full Synthetic 5w-20:
NOACK - UNKNOWN
SAPS - 0.8%
TEOST - 22.5 mg
Pennzoil Platinum 5w-20:
NOACK - 8.6% according to Pennzoil's tests, 6.5 in independent tests
SAPS - less than or equal to 1.3%
TEOST - 9 mg (unconfirmed)
Pennzoil Ultra Platinum 5w-20:
NOACK - 10.5%
TEOST - 9 mg
Pennzoil Gold Synthetic Blend 5w-20:
NOACK - 13.4%
SAPS - unknown
Quaker State Ultimate Durability 5w-20:
NOACK - 13.4%
SAPS - unknown
TEOST - 13 mg
Valvoline Maxlife Full Synthetic 5w-20:
NOACK - 9.3%
SAPS - 1.0%
Valvoline Synpower Full Synthetic 5w-20:
NOACK - 10%
SAPS - 0.93%
TEOST - 7 mg
Valvoline Dura-blend Synthetic Blend 5w-20:
NOACK - 11%
SAPS - 0.99%
TEOST - Between 8 mg and 13 mg (can't confirm exact for 5w-20)
Redline High Performance 5w-20:
NOACK - 8%
SAPS - unknown
TEOST - 29.1 mg to 31.4 mg range over 3 tests
Motorcraft Synthetic Blend 5w-20:
NOACK - 15.2%
SAPS - unknown
Motorcraft XO-5W20-QFS Full Synthetic
NOACK - 13-15% (unconfirmed)
SAPS - unknown
Motul Specific 948b 5w-20 (meets Ford WSS-M2C948-B NOT WSS-M2C945-A):
NOACK - unknown
SAPS - 0.78%
Amsoil Signature Full Synthetic 5w-20:
NOACK - 6.3%
SAPS - unknown
TEOST - 5 mg
Amsoil XL Extended Life Synthetic 5w-20:
NOACK - 9.9%
SAPS - unknown
Amsoil OE Synthetic 5w-20:
NOACK - 10.0%
SAPS - unknown
Castrol Edge with Titanium Fluid Strength Technology Full Synthetic 5w-20:
NOACK - 10.5%
SAPS - unknown
TEOST - 3.5 MG
Royal Purple "High Performance" API licensed:
NOACK: 9.5%
SAPS - less than 1%
TEOST - 9.9 mg
ENEOS Full Synthetic 5w-20 (NOT WSS-M2C945-A compliant)
NOACK: 9.5% (10.8% in independent tests)
SAPS:
TEOST:
Useful link I found that shows the current PQI test results for all 5w-20 oils they have tested:
http://www.pqiamerica.com/Feb2014/c...6,+2014&utm_campaign=4-21-14&utm_medium=email
Shared Google Spreadsheet containing oil information:
http://goo.gl/lsO3gp
NOACK - UNKNOWN
SAPS - 0.83%
NOACK - UNKNOWN
SAPS - 0.8%
TEOST - 22.5 mg
NOACK - 10.5%
TEOST - 9 mg
NOACK - 13.4%
SAPS - unknown
NOACK - 13.4%
SAPS - unknown
TEOST - 13 mg
NOACK - 9.3%
SAPS - 1.0%
NOACK - 10%
SAPS - 0.93%
TEOST - 7 mg
NOACK - 11%
SAPS - 0.99%
NOACK - 8%
SAPS - unknown
NOACK - 15.2%
SAPS - unknown
SAPS - unknown
NOACK - unknown
SAPS - 0.78%
NOACK - 6.3%
SAPS - unknown
TEOST - 5 mg
NOACK - 9.9%
SAPS - unknown
NOACK - 10.0%
SAPS - unknown
NOACK - 10.5%
SAPS - unknown
TEOST - 3.5 MG
NOACK: 9.5%
SAPS - less than 1%
TEOST - 9.9 mg
SAPS:
TEOST:
