I like many others have quickly grown tired over the past few weeks of hearing those annoying whirling hollow sounds and faux exhaust noises coming into my cabin caused by the sound symposer which Ford chose to install in the FiST... I finally decided to eliminate this feature without appearing as if anything was modified or removed...
The solution as already mentioned previously by a few others is very easy....I chose to just simply plug the source on the charge pipe that feeds the symposer box....And as a result of doing so I no longer hear those hollow swirling sounds which often occur during low-mid throttle accelerations...And quite frankly now I can really enjoy hearing my Cobb exhaust system which now sounds far better even in the cabin while cruising after that sound symposer function was effectively removed from the system...
Now if your only interested in not channeling the sound into the cabin you can just simply remove the symposer tube after the box which leads to the cabin...
But more importantly (IMO)....Considering that I've now raised max boost levels higher (with my current tune), along with some future projects planned, I simply wasn't comfortable having that much boost pressure channeled to a sound symposer box diaphragm which could get damaged over time and cause some problematic leaks to occur since the symposer source is taken directly off the charge pipe...As a side note: Eventually I'd like to have a pipe fabricated to replace the current stock pipe that connects from IC hardpipe (cold side) to the throttle body which would eliminate the port leading to the symposer...
Outlined and shown below is a "how to" ...(which btw was not original on my part as I have read through a few other examples posted on other forums)....
1) Spread the hose clamp open and remove the lower hose (see #2 in Pic below) from the Symposer box to charge pipe port..
2) Insert Dorman rubber (1" - 1.125") expansion plug (#02600) which you can purchase at any Autozone store for $2.99...
3) Once the rubber expansion plug was inserted and secured in place re-install the symposer hose back over the plug and then reinstalled the symposer box such that you'd never know anything was modified...
The entire project took less than 20 min and cost $3.00....
