I just ordered 6 of these for my new track wheels![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
15x9, +35mm, 4x100, between 12-13lbs(will know for sure when they arrive, I expect 12.5lbs or so)
Konig Helix, roll formed means the same as flow formed which means super strong and low weight, no reason to spend $500 each on forged wheels unless you just want to have them and or not willing to spend a few hundred on a 4x100 conversion
NOTE: these only fit the rear of the ST with serious other mods required, more camber and pulled and rolled fenders, pulling and rolling required up front as well.
Goodwinracing.com
These are made in 15x8 +25mm which is not optimal for our cars or I would get a set for my street tires.
They are made in 15x7, +35mm, around 11 lbs, $119 each and should be a great match for those wanting that size.
Compared to a $2k+ plus set of forged wheels you can get 4 of these very high quality wheels for in the $500 range, spend a few hundred on 4x100 conversion and save a butt load of money![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I could run the 15x7 for the street if I switch from my custom 11.75" GT rotor BBK to 11" rotors, I am considering it.
Just taking a break, back to work so I can finish up this big headache remodel project and get home and tear my car apart getting ready for the EFR turbo, BIG IC, and other pending mods![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Good day![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Rick
Goodwinracing.com
Good day
Rick
