Radar Detector Hardwire DIY for Ford Fiesta ST - Valentine V1 detector
Shmi
Fairfax
I posted this over on FiestaST.org, but wanted to share it here as well.
I hard-wired my radar detector, thought I would put together a DIY since I had to figure this out for myself because I couldn't find a DIY guide online! This guide is to install it clipped onto the passenger side sun visor, but you can reroute the wiring to set it up wherever you want.
Disclaimer: Don't break stuff. If you do, don't blame me as I accept zero liability. Ask questions if you're unsure and I'll be more than happy to answer them.
INGREDIENTS:
Pliers, electrical tape, a socket wrench with a 10mm socket and one or two 20amp mini ATM fuses. Heat gun optional. You MAY want to buy a spare 20amp fuse or two. In case you drop the 20amp fuse into the bowels of the glove box fuse box hell and never find it again. Mini fuses - ATM mini fuses.
A) ATM Mini Fuse Tap. You can find these at most auto parts stores. My local NAPA store had one in stock.
B) Ring wire connector. I'm not 100% sure which size (sorry) but it was at least 4mm inner diameter:
C) Spudger, or another plastic tool. I suppose you could use a dull butter knife but I don't recommend it as it will be used to wedge some trim apart for a few moments. I had a ton of these laying around because I work on computers a lot:
D) You'll also need the V1 hardwire kit that came with the radar detector. Specifically, the rounded module piece:
Mine has two thin wires coming out of the back (not pictured), one red (12v power) and one black (ground).
The kit also has a long telephone-wire-looking cable. You want that.
RECIPE:
What we're tapping for power is a 20amp fuse. Specifically, the windshield wiper fuse. This fuse is hot with power, meaning it only supplies power when the ignition is on. This way, your detector will shut off when you shut the car off. It won't drain your battery. It's also 12 volt.
Turn your car off.
1. Empty your glove box. Grab the sides and push them inward in order to lower the glove box completely, because we're going to tap a fuse in the fuse box located behind the glove box.
2. Pull the 20amp fuse out of this location and for god's sake DONT DROP IT!
2a. Take the 20amp fuse, and plug it into the fuse tap (A) so that you don't lose it for now. Take one of your other 20amp fuses and plug it into the other fuse slot on the fuse tap.
2b. Sorry I did not take photos of this step but it's not too hard. Message me if you have questions! Take the red 12v power wire from the radar detector kit module (D). Now, mine did not have anything at the end of it - it was simply severed. What I did was strip some insulation off the end of it, and connect it to the long purple wire coming out of the the fuse tap (A) that has a connector and heat-shrink tubing on it. Insert the wire, crimp it down with some pliers, and if you have a heat gun, go ahead and heat shrink it. If not, just wrap it up well with some electrical tape.
3. Take the black wire coming out of the kit module (D) and do the same as the other wire - strip the end of it, and push it into the ring wire connector (B). Crimp it down, heat it up, or wrap in electrical tape.
4. Back to this picture:
See that stud/nut to the right? That's your ground. Get your 10mm socket wrench and take the nut off. It takes quite a few turns. Don't drop the nut!
5. Plug the fuse tap into the fuse location that you pulled that fuse out of earlier. The one I circled on the left.
6. Put the ring wire connector (ground wire (B)) on the stud, and tighten the nut back down. You may notice that the fit isn't great, because the stud is in a recessed dimple, but the ring wire connector is flat so it wants to go on at an angle. You can just bend the ring wire connector near the base so that it sits down in that dimple. Tighten it up.
7. Test your detector! Do this before finishing up or else you'll kick yourself if it doesn't work. Plug the telephone cable (I mean, that's exactly what it looks like...) into the power port of the kit's module (D). Plug the other end into the radar detector. Turn the ignition and the detector on to try it out. Make sure your wipers still work too.
8. Working? Great! Move on. If it's not working, make sure you have two fuses plugged into the fuse tap and that they're both fully seated, and that the fuse tap itself is in the correct slot and also seated all the way in.
9. Unplug the telephone wire and grab your spudger or other thin plastic tool. You're going to insert it, carefully, somewhere along this dashed line:
While it's in there, wedge it open enough to feed the telephone wire (I keep calling it that) in through the crack and down into the fuse box area. Make sure you feed in enough of it.
10. Snake the wire forward towards the A-pillar. If you look carefully, there are panel gaps that you can fit the wire through easily. Do that, and keep feeding the wire up the A-pillar weather-stripping by peeling it back bit by bit:
11. Keep snaking it up the A-pillar. I followed this path:
...and up the front of the headliner. Here's a picture taken from the front of the car, looking backwards:
12. Keep feeding it over to the sun visor clip area. Mine ended up like this:
I had some extra wire left over so I just stuffed it up above the headliner at the top of the windshield.
Finally, go back to the glove box area. Plug the loose end of the telephone wire back into that kit module. The kit module should have adhesive velcro on it. I used that to fasten it to the passenger side of that fuse box area so that it wouldn't bounce around or rattle. You could also zip-tie it somewhere in there or just shake it until it stops crying. Umm..
Put your glove box back in. Just reverse the steps from earlier - push the sides in and put it back up in there. If by some chance you leaned on the glove box while it was in the down position, and it completely came off of the hinge (mine did!), it's not too hard to put back in correctly. Just push the sides in again and get the tabs on the sides of the glove box into the housing, then use your fingers to feel along the bottom of the glove box edge - the edge will have clips on it that snap onto the long black metal rod that it hinges on. You can clip in one side at a time, it was easier that way for me. It takes a decent push to get it to clip back on there. You may want to look at the back of the glove box or the hinge it clips onto to get a better mental image of what you're trying to accomplish, since you'll be working blind and by finger feel only.
That's it. Enjoy. PM me if questions.
Harvick
Great first post, repped+1
Welcome to the forums
S
Shmi
Fairfax
Thank you. Hope the community finds it useful. Really love these cars and want to contribute what I can!
MKVIIST
Welcome aboard Shmii, this is really great stuff you posted. I was thinking of installing a HomeLink integrated rear view mirror and this write-up is perfect.
Perry
Leawood
Nice job, and great description and pics. Well done!
Colin1337
Kirtland AFB
Repd. Great write up, I've been planning on doing this to mine for a while now, just havent got around to it
Yukon, OK
Nice guide. Will help when I get mine. Just one quick question. I notice the detector's line of sight's pretty close to the top of the windshield, where the glareshield area's at. This doesn't affect it's performance?
S
Shmi
Fairfax
Thanks everyone!
It doesn't affect it that I can tell. It went off a few times today during a long ride and most of the time the police were pretty far ahead, so it doesn't seem to interfere with it significantly if at all. [cool]
westcoaST
Corona
Great write up. I just purchased a rear view mirror mount and hard wire for my Escort 9500ix. Blendmount wants about $100.00 for their kit. Ebay has a similar kit for $37.00. The soldered ends are already included with the line. I plan on installing it this weekend.
San Diego County
Thank you for your well documented install. I did mine today using your guide.
Just a couple of updates from my install.
  • Be careful if you purchase the ATM mini fuse tap, the one I bought on amazon was slightly different (circuit blade style) and I didnt catch it until I was full into the install. A quick trip to Napa for the right part (mini blade style) got me back on track.
  • I used some velcro to mount the V1 supplied 2 prong jack to the side of the fuse box. It seems pretty secure.
  • When I was wrenching on the ground screw I knocked the glove compartment on to the floor. I took a look and saw how easy it was to remove and certainly provides a lot more elbow room without it in the way. Just pull straight out from the hinge point. See photos to see the connections.
  • I routed the cable a little different towards the bottom, I just kept going down the door lining all the way to the bottom of the glove box where there was a nice crease. See photo.
  • I'm using V1 mounting bracket I had in a prior vehicle that I got on amazon that mounts to the mirror which gives a real nice and sturdy connection that is fully adjustable.
MirrorMountTM Radar Detector Mirror Mount - V1 Radar Detectors
Thanks again and I help these notes help the next installer too. [:)]
View of hinge area with glove compartment completely removed. (below)
Bottom view of the glove compartment hinge area. (below)
Routing point from door lining to glove compartment area. (below)
FocusMike
Dearborn
Thanks for this tutorial, I just purchased that mirror mount. Going to try it next weekend.
Johns Creek
Great write up by Shmi! Only thing I did different was I pulled the weather strip out of its channel from the height of the fuse box, to the top of the A pillar. Then I simply ran the wire up the channel and across the top of the A pillar cover.
Dearborn
[MENTION=384]Shmi[/MENTION] - thank you. Just got my Fiesta and needed to know how to hardwire my V1.
Zormecteon
Kelso
I went to a local Car Audio shop a couple of weeks ago to have this done. It's not that I couldn't do it, I just didn't want to.. ...
I had the car there at 9:00-opening time. .. At about 10:30 I saw them opening up the rear passenger side door? .. .. about 11:00 I asked how it was going. They said they just sent their shop boy out for some different parts, as what they were doing wasn't working when they attempted to start the car. ?? I showed them this article and said all it takes is a fuse tap.... guy says " we don't use those here"... .. about 11:30 I ask again about how its going and show another guy the this article.. he says they've sent the shop boy for some more parts... .. 12:30 I get the car back and they've put it in just like it shows HERE, fuse tap and all.... I could have done it myself in 1/2 and hour.. but didn't want to.. instead I wound up paying for an hour and a half labor.. (they spent over 2 hours with two guys)..... anyway...lesson learned, and thank you for the write up.
westcoaST
Corona
That why I did this myself on both my Fiesta ST, and then again on my Focus ST. I installed both a autodimming mirror with Homelink and a direct line to my escort radar detector. Only took two add a fuse taps.
Sent from my SM-G935V using Tapatalk
Arizona
Thanks for the awesome writeup! Did this yesterday--the "add-a-fuse" I bought came with a 15a fuse so to make it match I tapped the rear wiper's 15a fuse (4 down from the top on left side) which gives the same on/off with the ignition. I also ran the "phone line" end of the cord directly out the side of the glove box and up the weather stripping so I didn't have to pry any panels.
Here are the parts I used:
Radar Mount--https://www.amazon.com/gp/product/B0063N7OZ2/ref=od_aui_detailpages00?ie=UTF8&psc=1
Power wire kit--http://www.ebay.com/itm/ESCORT-8500-S50-Radar-Detector-Direct-Power-Cord-from-Fuse-Box-DP-ESCT-/112337967382?
