I guess I'd throw this up....pardon me if someone already has.....
1st step remove passengerside a/c bolster screw clip.....
2nd step remove a/c bolster panel....
3rd step....
4th step....remove bolts and unplug the sensor/switch....
5th step....next two bolts ......
Then remove this a/c baffle near the glove box to get at the top screw easier.......
6th step.....get take the cover off.....pull on filter at the bottom to get it out. It's ok if it gets pulled on and squished. It pretty resilient at springging back. Make sure you point the arrow on top of the filter twords you on the install.
Good luck....now go change the cabin filter...
