I figured I'd make a thread with Virtual dyno results, and post what (i hope) is the correct configuration for our car, so you can get consistent comparable results.
First this is How I setup my totally stock FiST, I looked up everything online (I used the frontal surface area from a 2011 standard fiesta since I coudln't find ST specific)
EDIT: My tire size is rounded (for the stock wheel/tire), as dyn085 pointed out, it should be 23.46 not 23.50.
As suggested in this thread by rick, here are some parameters that may be useful post in the thread to get more comparable results:
1) Altitude
2) Road used, as flat as possible or one uphill and one downhill run and noted so we can average the results.
3) Road material, estimated grip relative to other surfaces, if sandy, damp, etc......
4) Wind direction and rough estimate of speed
5) Temperature and if possible humidity
6) Tire and wheel weight
7) Tire width
8) Tire type, summer only, all season, as pertinent if pulling from a dig, if experiencing traction losses.
9) Tire air pressure
10) Extreme camber if so
11) LSD, open diff, any nanny's enabled, etc.
12) Weight of your car, if you're just estimating or if you have actually had it weighed with you in it
And a really good read posted by dyn085 which is a post on the Evo forums telling you how to get consistent results with Virtual Dyno Logs:
http://www.evolutionm.net/forums/evo-dyno-tuning-results/619146-how-use-virtual-dyno-properly.html
Here's a bunch of my Virtual Dyno results from a bunch of 3rd and 4th gear pulls. All Cobb OTS Stage 2. I just bought Accesstuner so I'll probably post more as I improve my tune (I'm a n00b so it will probably take a while). Altitude 550 ft above sea, temp is vaired per run, 60-80 degrees. Stock everything for tires and mods. Traction control off.
One thing I forgot on all of them was to add my weight (300 lbs) so they're a little lower than what they "should" be.
Let me know if you think the config I posted is wrong in any way.
EDIT: Oh yeah, the software is free and you can download it here: http://www.virtualdyno.net
It works by uploading your Accessport logs. It already supports accessport, so you don't have to tell it what to do, just point it to your files. Default logged data is fine.
1) Altitude
7) Tire width
