This was my first mod, but not seeing any like it on the forum, thought I would share.
Loosing weight was a goal, bit a functional rear bed was #1 consideration, I sold my 4x4 Grand Cherokee and need hauling capacity.
Found a fiberglass/foam composite called Thermo-Ply, 1/2 " thickness at 30 lbs/cf density (marine supply) and used most of one 4 x 8 sheet. Its built in two sections and press fit, no fasteners.
Glued pieces together with PL5200, then added a little glass and epoxy resin underneath to reinforce joints.
Completely removable in 3 minutes. Piano hinge cover over spare tire compartment for secure storage (I carry a few tools, bungees and cargo net, tire repair kit) but lots of room left,
Front section weighs 20 lbs, rear section 13 lbs, center support and custom waterproof mat 3 lbs more. Carpet patches velcro attached at sides. Carbon trim on top edge is structural, side panel veneer just for looks.
