Soon you will be able to buy the WW 11.75" GT rotor 6 piston DP caliper setup to fit 15" wheels. I am paying to have mounts made and the pattern will be available so easy to order and for a good price. There are much cheaper rotors that fit this setup as well, pads are cheap and a ton available.
Rear brakes are a bit more effort but I am making mounts right now for 4 piston WW calipers with parking brake arms, 11" GT rotors, modified knuckles, etc....but rear brakes for a bit of work with the same great rotors but are much less in that size and pads are less and many options as well.
Depending on cost to mod the parts unless you do it yourself I imagine both front and rear sets with pads and SS lines might come in under $2k for the front and rear
Do the hub re-bore and you can get 15x8 in the 12 lb range for $120 or so, roll formed, 15x9 $130 range, roll formed and 13 lbs as well as the new version of the 15x9 12 lb roll formed UL6 which is a beautiful wheel but will have to be careful to ensure they fit over the brakes.
If they do later on I will sell my 15x9 wheels and get them as always wanted the UL6 but they were no longer sold while working on the new version.
225/45/15 RA1, $40-80 each fresh from race teams, I always get the best as shipping costs the same, $400 or a bit less a set to your door, and you can get A6, R6, R888 and others.
My 15x9 with 225 tires, balance weights, aluminum valve stems, 31.6 lbs per corner!
There is a method to my __________after all
