Car is a 2014 with 40k miles bought new. Stock except for RMM and shifter bushings. Daily driver, regularly maintained, adore the car.
The problem - accelerating in 3rd gear when suddenly engine bogs, car slows and RPM drops to idle. Push gas pedal - nothing happens. 2-3 seconds later throttle returns and car runs normal. Then while coasting to the next light, engine stalls, but starts back up & runs fine. Same problems happen again a handful of times over the next few days across all gears.
No CEL, no wrench light, no stored or pending codes. All live sensor data appears normal. Fluids are fine, no boost leaks. Not bad gas - I've had the same problem with 2 tanks. Power feels a bit low, but that might be paranoia.
Any ideas? I'm a capable mechanic but without a trouble code to point me in the right direction I'm left guessing, which is going to get expensive.
Happy to give more info if needed - I really appreciate the help.
