Stock Front and Rear Suspension Changes Between Early/Late Production
Sterling, VA, USA
I couldn't find a dedicated thread for this, so I wanted to post the information and the sources for future reference. My apologies if this already exists somewhere and my search-fu was weak. There is spec'd change in rear beam thickness, despite the part numbers I found via Tasca to be the same for the rear beam from 2014-2017. Cutoff dates below are culled from the date of supplement revision, not actual production job information. Having a more reliable set of cut off dates would be great for future junkyard hunters.
2014-2016 (through 9/16 production) Fiesta ST Suspension specs:
Suspension Specifications
Item Description
MacPherson strut with L-arm front
suspension and revised knuckle
Front suspension
Rear suspension Twist beam (7.5 mm thick)
Front spring rate 30 N/mm (171 lb/in)
At a Glance
Item Description
Rear spring rate 25 N/mm (143 lb/in)
Front stabilizer bar 19 mm (0.75 in) diameter
Rear stabilizer bar Not applicable
Source:
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/14fstst1e.pdf - 2014 Fiesta ST Supplement
http://www.fordservicecontent.com/F...-ST-Supplement-version-2_st_EN-US_10_2014.pdf - 2015 Fiesta ST Supplement
http://www.fordservicecontent.com/F...-ST-Supplement-version-1_st_EN-US_05_2015.pdf - 2016 Fiesta ST Supplement
2017 (2/16/16 Production+)-2018 Fiesta ST suspension specs:
Item Description
MacPherson strut with L-arm front suspension and revised
knuckle
Front suspension
Rear suspension Twist beam 0.3 in (8.5 mm) thick
Front spring rate 154 lb/in (27N/mm)
Rear spring rate 131 lb/in (23N/mm)
Front stabilizer bar 0.83 in (21 mm)
http://www.fordservicecontent.com/F...pplement-version-1_su_EN-US-EN-CA_10_2016.pdf - 2017 Fiesta ST supplement
http://www.fordservicecontent.com/F...&div=f&vFilteringEnabled=False&userMarket=USA - 2018 Fiesta ST supplement
If anyone could provide more clarity on build cutoffs for US spec production changing from the old rates to new, that would be awesome. Most people wouldn't notice a difference between relatively minute changes like these, but I haven't checked yet on what the old vs new damper part numbers (and maybe bump stops) are. Someone looking to bolt ST parts onto a non-ST may find this useful.
Edit: thanks for the updates in the thread. I've updated this post accordingly.
Austin
For H Street purposes, could one with a 2017 bolt on springs from the earlier models or would that not be allowed? Sad to see such a shift in spring rates..
felopr
JD
so, later models have bigger front sway bar and bigger rear twist beam but softer spring rate? (only 20lbs apart tho)
later models should be "more rigid" but slightly.
We still dont know 1 variable, damper rating. Are they the same?
BRGT350
Grand Haven
There are multiple reports that the 2014 bushings are stiffer than the ones used on 2015+. The 2014 cars used the bushings from Europe, but those were deemed too harsh for the US market. I have driven both a 2014 and 2015 and couldn't tell the difference.
Truth in Ruin
Lincoln
With the cutoff date being 02/16/2016, the "2016" you drove, could be either spec.
You don't happen to know if your "2016" was pre or post change date do you?
Iā€™d have to look, but Iā€™m willing to bet the springs are stiffer in my 16. Itā€™s a night and day difference.
danbfree
Tigard, Oregon, USA
The '14-'16 are stiffer out of the box with thinner bars, and even though the '17+ goes from 19mm to 21mm for the FSB and a mm thicker on the rear beam to help against bump steer it does have a bit of extra body roll from the softer shocks but is still pretty harsh as a daily... for best of both worlds at reasonable refinement, you can do the Eibach springs which lower an inch, provide a less harsh but still nice and firm ride with progressive springs along with their matching beefy front (25mm over 22 stock) and rear sway bar (22mm, no rear stock) kit, Whoosh has the best price anywhere on the Eibach kit. For all out performance, the Swift Spec-R are the best springs, I believe they have the right balance being linear in the front and slightly progressive in the rear.
R
Sterling, VA, USA
Thread Starter #15
Now that I've owned an early 2014 and have over 10k miles on my 2018, the 2014 was the sharper car, but the 2016 is a better balanced daily driver. The 2014 transitions with more immediacy on track, and from the factory, the alignment was spot on. My 2018 arrived with a maximum allowable toe-in and still feels more sluggish on turn in despite having less body roll. In the city or on any road with less than perfect pavement, the 2018 has a less jarring ride due to what feels like less rebound to my un-calibrated butt. I somewhat miss how frenetic the ride was in the 2014.
danbfree
Tigard, Oregon, USA
Exactly, with softer shocks, the '17+ does have a touch more body roll and a little less sharpness, even with a fatter stock front sway bar than previous years but is more tolerable as a daily... but also keep in mind that going with an even fatter sway bar will reduce body roll further and provide more sharpness to offset the softer shocks.
Ford ST
Pleasant Garden
From 2/16/16 have the suspension update.
haste
Eastern
Yeah, my '17(built 11/17) feels like a Cadillac compared to my '15(built 8/14).
danbfree
Tigard, Oregon, USA
Fronts were updated starting 2/16/16 and rear update started 6/14/16, for MY '17... So late '16's will have the front changed but not rear, kinda weird, they must have realized they needed to match up the rear to the front...
2016 Model Year
FRONT SUSPENSION
-4/1/2015 and 2/15/2016= original spec
-Updated on vehicle Build Date starting: 2/16/2016
REAR SUSPENSION
-Vehicle Build Date between: 2/16/2016 and 6/13/2016= original spec
-Updated on vehicle Build Date starting: 6/14/2016
This is condensed from the thread HERE
The front includes jump from 19mm to 21mm FSB as well, otherwise the main change in part# is 10% softer rate shocks/struts. and rear includes thicker rear beam.
Edit: As @Ford ST mentions below, all replacement part sites now show the rear updated as of 2/16/16 so maybe they really did front and rear at the same time, which makes more sense.
Ford ST
Pleasant Garden
That's not how the OEM replacement parts are sold. You will see from the picture below about the rear axle beam.
