Dual Exit Exhaust
Peterson
Paramus, NJ, USA
I know there was a guy that built a dual exit (dual tailpipe) exhaust around the USDM Evap canister in the rear of the car. I’ve been searching for a day or so now, and I can’t find the post.
Can anyone point me in the right direction?
TDavis
Columbia
I've always wanted a dual quad tip on the FiST. It would be beautiful
Peterson
Peterson
Paramus, NJ, USA
Eh. I’d rather just cut the stock bumper. Not a fan of the Pumaspeed design.
LilPartyBox
NYC
Haha agreed. It looks like something you'd buy at an auto parts store along with underbody LEDs and a chrome 4" exhaust tip
olathe
I have a dual exit 3" exhaust but I just deleted the evap canister.
Peterson
Peterson
Paramus, NJ, USA
Thread Starter #15
Could you elaborate on the Evap delete? I’m still learning lol. What is the Evap canister for anyways?
alexrex20
Spring
You will get a check engine light if you delete it. If your state has emissions inspections, an evap delete is instant fail. The evap canister collects fumes from the gas tank and dumps them into the intake manifold.
^^^THIS!
I would think about relocating it elsewhere to gain clearance for that custom system, but NOT eliminating it completely. [nono]
wspec may have had a tuner permanently 'write out' the DTC code for this (IF that's even possible [dunno]), but it may help the system deal with 'vapor lock' in the summer, so not too sure it's a good idea, even if there is no cluster light showing.
Peterson
Peterson
Paramus, NJ, USA
Thread Starter #18
Well then. That’s staying put and the exhaust is routed around it ??????
alexrex20
Spring
The CEL can be effectively turned off by disabling that particular DTC completely, but it can still cause a emissions test fail because the test reads your computer's readiness monitors and a disabled DTC will read as Not Ready which is basically a failure.
Thanks Nixon.
To clarify though, the evap system is purely an emissions device and deleting it does not effect your engine at all. If your state does not do emissions inspections then I would delete it.
There are states which do not do an actual emissions 'sniffer and/or dyno' test, but they WILL still fail you on the OBD 2 plug-in that they still do, so you will fail due to monitor readiness not showing correctly (yes, unless your state does not even do a plug-in test).
This is why I was asking IF it is even possible to 'write out' the whole EVAP system from the ECM, and somehow 'write in' a readiness monitor showing 'positive'.
Peterson is in Joyzee, and the last time I went through their (Parsons run) inspection some 6 years ago, they DID do the OBD 2 plug-in, and they also still did the gas cap 'leakdown' test, which leads me to think that they DO care about the whole EVAP system. ;)
