So I'm prepping the car for a trackday at Buttonwillow on May 14th.
I'm changing fluid and most likely putting in stainless lines and I have the boomba deflectors so hopefully brake fade won't be too big of an issue.
I inspected my pad life today with a pad measuring tool. Fronts: 6mm outside pad, 4 or 5mm on the inside pad. Rears: 5mm on outside pad, 4mm or so on the inside pad.
This falls in the yellow gauges, under 4mm it's would go to the red gauges which obviously means replace.
Is that enough for the day? And what would be the best scenario if I buy pads: 1.Buy pads and install them now 2. Buy pads and install them at the track if burn through my current pads.
Also, I'm open to suggestions on what pads people are running that are a decent compromise for street/track/autox. I don't care about dust, but my rotors are okay for now, wouldn't mind to get 1 or 2 more sets of pads out of the rotors.
Thanks!
Thanks!
