How much power can 2.25" exhaust support?
Based
Nope
I am about to order the Borla exhaust #140525. I'm just wondering if I wanted to go hybrid turbo in the future, how much power would the 2.25" exhaust be able to support? And when I order this exhaust (or any new exhaust), do I need to get any type of gasket(s)? For the downpipe?
B
Based
Nope
Wow I guess you gain a lot of potential just by going from 2.25 to 2.5"... But the Borla sounds so good :/. I don't really like how the bigger exhausts sound on this car it sounds to burbly
Tucson
Wow I'm glad I went with 3 inch mbrp! But yes based it is so loud.
kivnul
U.S. Army Veteran
Deer Park, WA
This doesn't seem accurate, unless I am reading it wrong. It seems like there are at least a few members making significantly more power than what the above specifies.
From what I understand, the Volumetric Efficiency suffers if you restrict the exhaust after the turbo.. thus the turbo has to work harder to get the same HP. So it would totally be possible to run an undersized exhaust and get good power numbers, but you could get better numbers with a bigger exhaust.
jmrtsus
Ooltewah
I find those number to be shaky, especially since we have a 2.17 system not even a 2.25........maybe the forced induction has something to do with it. The MP215's typically push close to 220 on the stock cat/exhaust. Many forum members far exceed these numbers.
Suburbs
That makes more sense... the graph is a little misleading as it states "Max HP"
flagstaff
I imagine I could get another 30-50 whp with a 3". If there was a sort of quiet cat back, I would get it. I had a CPE cb for a few hours and went back to stock cuz it was so loud. I have no cat though.
re-rx7
Ardmore
Not likely. It's been tested over seas that a larger exhaust nets almost njothing in the hp dept. DI changes everything.
Berkley
For comparison I dynoed at 249/267 with C39 Hybrid on stock exhaust. During testing of DHM new 3" exhaust, which I am buying when it comes in, we Vdynoed 280/302. Mods in my sig. It was a noticeable difference we did not expect. Only thing I can think of is the hybrid likes the larger piping.
flagstaff
So think the stock exhaust is not restricting my gen 2 gtx2860 dhm kit at 29 psi. Lol.
re-rx7
Ardmore
Actually no. Not as much as you think. 5-10whp maybe. They tested a efr fist overseas with the large exhaust hardly anything. 30-50whp is funny though.
A7xogg
Hampton roads
It's more than piping size, exhaust design plays a part especially if the exhaust design create swirl then the exhaust gases get forced out naturally. If an aftermarket DP doesn't make more power than stock one on stock turbo then exhaust size won't. Also if you don't dyno comparison at the same dybo on the same day, a dyno comparison means nothing especially a vdnyo because a vdyno adds more variables. On bigger than stock turbos I could see bigger exhaust adding power but not as much as venders and ppl think
B
Based
Nope
Thread Starter #19
Well I decided to order the Borla. It sounds just too good for me not to get it
IF there is one single area of the aftermarket where we have too many great choices for this car, it is catback exhaust systems. [wink]
